Only limited number of folders are indexed/recog. (solved)
Postby Taxicletter » 12 Jun 2017, 09:49
I'm using RuneAudio on RPi3 with HifiBerry DAC+ and an external USB SSD drive.
I'm indexing my music for the first time, it took all night to update, but only 5 of the 40 folders are indexed. I mean: I only see those 5 folders in the folder-view and only those are indeed findable searching for albums or artists.
I read this: post21260.html?hilit=usb%20drive#p21260
But as for as I can see, permissions are the same on the missing folders.
In /var/log/runeaudio/mpd.log I see something about missing headers, but not as much as the number of missing songs (so I don't think that's about the problem).
Most of the folders contain mp3's and FLACs. Some folders have a jpg with cover art.
What can I try?
Should I edit the udevil.conf file, changing ro to rw, like mentioned here: adding-files-to-mounted-usb-drive-t3253.html#p11932 ?
Taxicletter
Re: Only limited number of folders are indexed/recognised
Postby Taxicletter » 13 Jun 2017, 09:17
There was some disk error. I reformatted it and put the music again on it, and now every folder is recognised.
Taxicletter
Postby hondagx35 » 13 Jun 2017, 10:41
Hi Taxicletter,
thank you for posting what the issue was.
