Optimal Raspberry Pi for Pihole?
Postby TingxoGamchu » 15 Apr 2024, 07:46
Seeking the Ideal Model Solely for Network Pihole Operation. Is the PI Zero W Sufficient? Deciding on the Best Raspberry Pi for Dedicated Pihole Usage. Guidance Needed on Selecting the Perfect Pi Model.
TingxoGamchu
Re: Optimal Raspberry Pi for Pihole?
Postby NeerMohan » 08 May 2024, 11:14
Absolutely! A Pi Zero W is totally capable of running Pi-hole for your network. It's a great budget option and uses very little power.
Here's the thing: if you plan on just using it for Pi-hole, the Zero W is perfect. If you ever want to add other services or mess around with the web interface, a Raspberry Pi 3B+ or 4 would be a smoother experience.
Let me know if you think you might want to do more down the line, otherwise the Zero W rocks for Pi-hole!
NeerMohan
Postby LeighP » 11 May 2024, 21:07
You can run PiHole on the the PiZeroW but I would recommend maybe a Pi3B with a hard wired connection.
LeighP
Postby kernuo » 10 Jun 2024, 04:28
kernuo
Postby tsawyer » 31 Jul 2024, 18:49
tsawyer
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
