[SOLVED] OPUS audio
[SOLVED] OPUS audio
Postby Jck » 27 Nov 2014, 09:22
Hello everybody,
does RuneAudio support opus audio format? AFAIK, MPD should support it since version 0.18 (http://goo.gl/hYb1vI), but none of my .opus files are shown in the library.
Thanks!
Jck
Re: OPUS audio
Postby ACX » 27 Nov 2014, 11:33
Hi Jck,
I'm afraid we left it out in the build configuration:
https://github.com/RuneAudio/RuneOS/blo ... GBUILD#L37
Re: OPUS audio
Postby Jck » 27 Nov 2014, 11:55
Is it been left out for optimizations purpose?
If I really really need to read my opus file, can I rebuild it enabling opus decoder or is it a bad idea?
Thanks!
Jck
Re: OPUS audio
Postby ACX » 27 Nov 2014, 13:17
You'll surely help us if you test that - you can try to recompile the package including OPUS audio support, and see if you notice any issue of degraded performance.
Re: OPUS audio
Postby Jck » 27 Nov 2014, 13:23
Ok, I'll give it a try.
Jck
Re: OPUS audio
Postby Jck » 09 Dec 2014, 12:15
I eventually managed to recompile and install the latest mpd version (19.6) with the --enable-opus option and everything seems to work without problems.
Only thing I noticed is that bitrate is always "0 kbps" while playing .opus file.
Jck
Re: OPUS audio
Postby ACX » 10 Dec 2014, 00:40
Re: OPUS audio
Postby Jck » 10 Dec 2014, 11:11
Jck
