Performance
Re: Performance
Postby Midnight » 25 Feb 2014, 09:38
Midnight
Moderator
Re: Performance
Postby ACX » 25 Feb 2014, 10:20
Re: Performance
Postby Midnight » 25 Feb 2014, 10:29
Of course the I2S DAC has nothing to do with USB, but still all data is accessed via USB (ethernet, USB stick). This shouldn't be a problem though ;)
Midnight
Moderator
Re: Performance
Postby ACX » 25 Feb 2014, 14:39
Re: Performance
Postby Midnight » 25 Feb 2014, 14:49
BTW: did you already compare the performance of Raspberry Pi to Beaglebone Black? For example how long it takes to create a music database from a directory. Or how responsive the runeUI is.
Just interested because the BBB CPU should be twice as fast as the RPi CPU.
Midnight
Moderator
Re: Performance
Postby ACX » 25 Feb 2014, 16:16
BeagleBone Black is quite faster than Raspberry Pi in almost every task, and does not have critical limits on the USB bus. If you don't need more than 1 USB port and you are going to use it via Ethernet, then the BBB is a very good performance/price option.
