Pi 2 and Hifiberry
Re: Pi 2 and Hifiberry
Postby fortheshire » 02 May 2016, 22:56
I have used the same SD card on the test image and on RuneAudio. I followed the instructions posted in the Docs section of this site to image the card.
fortheshire
Postby rastus » 03 May 2016, 03:34
Could be micro SD card issues, if treated 'badly' (constant reboots) they may fail. I used a program to 'wipe clean' the SD card some time ago when I had issues of it not booting correctly some time ago.
rastus
Postby fortheshire » 03 May 2016, 04:58
Do you remember the name of the program?
fortheshire
Postby rastus » 03 May 2016, 06:38
You can use SD Formatter 4.0 for SD/SDHC/SDXC.
"This software formats all SD memory cards, SDHC memory cards and SDXC memory cards. SD Formatter provides quick and easy access to the full capabilities of your SD, SDHC and SDXC memory cards."
"The SD Formatter was created specifically for memory cards using the SD/SDHC/SDXC standards. It is strongly recommended to use the SD Formatter instead of formatting utilities provided with operating systems that format various types of storage media. Using generic formatting utilities may result in less than optimal performance for your memory cards."
Download and install the correct version (Windows or Mac)...
https://www.sdcard.org/downloads/formatter_4/
Full documentation is available on that web site. But put simply...
1. From the "Drive" drop down menu, select the drive letter you wish to format.
2. Press the "Option" button.
3. From the "FORMAT TYPE" drop down menu, select "FULL (Overwrite)".
4. From the "FORMAT SIZE ADJUSTMENT" drop down menu, select "ON".
5. Press the "OK" button... and wait until it finishes.
WARNING-1: MAKE SURE you select the correct drive before proceeding!!!
WARNING-2: This WILL OVERWRITE any software on the selected card!!!
WARNING-3: You have been WARNED!!!
rastus
Postby fortheshire » 03 May 2016, 18:24
I have ran the software and reimaged the card and it is still happening.
I will try another card and let you know the results.
fortheshire
Postby fortheshire » 04 May 2016, 01:06
I have tried a second card and am having the same issue.
I am really at a loss here.
fortheshire
Postby rastus » 04 May 2016, 01:25
rastus
Postby fortheshire » 04 May 2016, 02:04
Both LEDs are lit up.
fortheshire
Postby rastus » 04 May 2016, 02:05
rastus
Postby fortheshire » 04 May 2016, 21:43
Anyone else have any suggestions?
fortheshire
Users browsing this forum: Baidu [Spider] and 34 guests
