Pi 2 and Hifiberry
Pi 2 and Hifiberry
Postby fortheshire » 01 May 2016, 21:24
I need some help setting up my Pi 2 to work with HiFiBerry and RuneAudio.
I have RuneAudio currently working with no issues, however I bought a Hifiberry and after installation I am just getting the Multicolored splash screen.
I have edited the config.txt as I saw in other posts to no avail.
Any other suggestions would be appreciated.
fortheshire
Re: Pi 2 and Hifiberry
Postby hondagx35 » 01 May 2016, 21:31
Postby fortheshire » 01 May 2016, 21:36
Thanks for the quick reply! I used a Mac to set it up. If I unplug the hifiberry from the board, everything works fine again. I have the DAC + RCA and I uncommented the corresponding line in the setup file.
fortheshire
Postby hondagx35 » 01 May 2016, 21:46
Hi fortheshire,
this is strange and shouldn't happen.
If i remember right we had this once and it was a defective hardware or a .
I would try the to be shure the hardware works.
It also would be helpfull to know the version (RuneAudio) you are working on?
Postby fortheshire » 02 May 2016, 16:59
I have tried the test image and it worked correctly.
I have re-imaged the card with RuneAudio_rpi2_rp3_0.4-beta_20160321_2GB and changed the setup.txt again and still received the color splash screen.
fortheshire
Postby hondagx35 » 02 May 2016, 17:04
Hi fortheshire,
the image works definitively with the Hifiberry DAC.
Please post your config.txt (if possible uploading as zip file).
Postby fortheshire » 02 May 2016, 17:11
Here is my config file.
https://mega.nz/#!pgc0mabZ
fortheshire
Postby hondagx35 » 02 May 2016, 17:15
Postby fortheshire » 02 May 2016, 18:11
fortheshire
Postby hondagx35 » 02 May 2016, 20:57
