PI Zero W - totally confused - my options
Postby GreenGrass » 17 Apr 2020, 12:39
Totally new to this & totally confused
here is the stage im at.
I have the image on the sd card in Rasp PI Zero w. (with USB stick) its plugged into a HDMI on a normal tv, it has a black screen with RuneAudio Login:
I can access the front end of Runeaudio on Wifi via my laptop and when a song is played the sound comes out of tv!
I have a 17inch touchscreen in a case, i can plug the laptop into this and control Runeaudio on touchscreen, but the sound is coming out of tv.
how do i get the sound to come out of the laptop?
can the rasp PI be connected directly to the touchscreen elimnating the laptop ( if i am using laptop there is no need for PI really)?
im trying to make a stand along jukebox. can Runeaudio be used in this way?
Thanks for any help, i just want to run the Rasp PI to play music via touchscreen!
GreenGrass
Re: PI Zero W - totally confused - my options
Postby Taff » 26 Jun 2020, 16:13
you can select the output audio device from menu/MPD ( top right of the screen ) It seems it is set to to HDMI out at present.
You will need an alternative output device connected to the Pi, a cheap USB audio box for instance, or an HDMI audio splitter, although that will probably need some extra setting changes to the ini files to allow HDMI without a screen connected.
edit. Re-reading your post, unless I am missing something, I don't think it is possible to send the audio back to the laptop, the system is intended to play to an external amp / speaker setup.
Taff
Postby LeighP » 15 Aug 2020, 09:52
Your audio will not play out of the laptop - you use that to control the system. There is no streaming involved.
Add a pHat DAC or similar to your Pi Zero W and play the audio back through an amp or speakers.
LeighP
