Picobber v2.1 DAC
Picobber v2.1 DAC
Postby Nob » 25 Jan 2015, 10:25
I recently bought Picobber V2.1 DAC from AlieXpress for my Raspberry Pi 2011.12 (I think a B version).
The red led on the Picobber is shining, so I guess the hardware DAC is plugged well on the Raspberry Pi.
Unfortunately I can't select the Picobber in the settings of RuneAudio. But I've read it has a similar chip as the Hifiberry, so I selected that one. But no dice, so I went to alsamixer to see if the sound wasn't muted, but when I selected the HifiBerry, alsamixer said: no controls.
Anyone any suggestions to get the Picobber working (or maybe a way to debug some more?)?
Thanks in advance!
Nob
Re: Picobber v2.1 DAC
Postby RubiksCube » 25 Jan 2015, 13:35
This might seem like a stupid question, but have you soldered the P5 header pins on the raspberry pi?
check this page about 2/5th from the bottom:
RubiksCube
Postby Nob » 25 Jan 2015, 13:52
Not a stupid question at all...
The connector wasn't included, so I guessed it wasn't necessary.
I was wrong...
Now buying a connector and soldering...
Thanks!
Will let you know the outcome.
Nob
Postby RubiksCube » 25 Jan 2015, 13:54
Cool, just make sure that your PI has the holes for the connector.
Looking forward to hearing more about your project.
RubiksCube
Postby ACX » 25 Jan 2015, 16:06
Hi Nob, when you have the Picobber DAC properly connected, please post here your debug info via Pastebin, so we can collect some useful data about it.
Postby Nob » 25 Jan 2015, 19:14
Ok, I will let you know, but it might take some time, I ordered a p5 connector from AlieXpress and most of the time, it takes a few weeks to get here (Europe).
Nob
Postby ACX » 25 Jan 2015, 21:05
You should have gone into an electronics shop in your nearbies, it cost only a few cents :)
Postby cubix » 27 Jan 2015, 20:07
cubix
Postby ACX » 27 Jan 2015, 21:02
Postby cubix » 28 Jan 2015, 05:25
cubix
