Pifi+ not recognized by Runeaudio 0.3 beta
Postby mlihl » 09 Mar 2016, 21:27
I'm desperately trying to get my Pifi+ card working with Runeaudio. I uncommented this section in /boot/config.txt:
# Uncomment one of these lines to enable an audio interface
#device_tree_overlay=hifiberry-dac
#device_tree_overlay=hifiberry-dacplus
device_tree_overlay=hifiberry-digi
#device_tree_overlay=hifiberry-amp
#device_tree_overlay=iqaudio-dac
#device_tree_overlay=iqaudio-dacplus
After a reboot, I still cannot see the option in MPD. Did I forget anything else in config?
Debug doesn't show this card either...
Thanks,
Michael
mlihl
Re: Pifi+ not recognized by Runeaudio 0.3 beta
Postby hondagx35 » 09 Mar 2016, 22:29
Postby mlihl » 09 Mar 2016, 22:46
it's a Digi+ (forgot to mention in my first post)
release version: 0.4 (build: beta-20141216)
mlihl
Postby hondagx35 » 09 Mar 2016, 23:02
Hi Michael,
so "device_tree_overlay=hifiberry-digi" should work.
- check the debug output for errors (MENU->Debug)
- did you edit this ffile on Windows? (check lineendings)
Postby mlihl » 09 Mar 2016, 23:18
No obvious errors in debug, it simply won't show the hardware card:
https://www.dropbox.com/s/y94wosxfr72la ... I.pdf?dl=0
I edited /boot/config.txt using nano via a SSH session.
Funny thing, if I enable Hifiberry DAC, MPD will show it as active but of course no sound
going out to my DAC. The Digi+ driver won't do anything.
Can this be a hardware fault?
Regards, Michael
mlihl
Postby hondagx35 » 09 Mar 2016, 23:31
Postby mlihl » 09 Mar 2016, 23:48
so enabling I2S = on in the config should not be necessary?
I'm kind of wondering if there's anything else I could have done wrong because obviously some people could get the card to work. But no luck for me...
Regards, Michael
mlihl
Postby mlihl » 10 Mar 2016, 00:18
Success!!!
Finally got it to work, after moving the board it suddenly turned on in MPD. Probably a hardware issue, I'll investigate this. Thanks again for your help!
Michael
mlihl
