Play podcasts ?
Play podcasts ?
Postby Pir » 04 Dec 2016, 15:19
I've been using Rune audio for a few weeks now and I'm very happy with it.
However I tried to play podcasts recently and realized there didn't seem to be any obvious way to do it.
Have I overlooked something ?
Thanks in advance for your help.
Pir
Re: Play podcasts ?
Postby hondagx35 » 04 Dec 2016, 19:44
Hi Pir,
playing single podcasts is possible with RuneAudio.
You have to enter the streaming URL for that single podcast as webradio.
Playing podcasts from a RSS feed is not possible at the moment.
I did some tests with "" and it works great.
We have to see if it is possible to implement this feature in the future.
Re: Play podcasts ?
Postby Pir » 08 Dec 2016, 09:25
Thanks for the suggestion. I'm indeed looking for a solution for RSS feeds (my friend will be playing podcasts and doesn't want to have to extract urls manually every time).
What is you "workflow" with this bash script ? Can it be installed and run on the same machine running Rune Audio (a RPi in my case) ?
Thanks in advance,
Pir.
Pir
Re: Play podcasts ?
Postby Pir » 10 Dec 2016, 14:49
I figured out how to ssh into my RPi, and downloaded the bash script from github.
It generates pls and m3u files all right, but I have no clue how to get Rune Audio to play them.
Adding them to /mnt/MPD/Webradio fails because Rune can apparently only read a single item in each list, and the playlists I get from the rss feeds have more than one.
I also saw that there was a /mnt/MPD/Podcast folder, but I don't know how to access it from RuneUI.
Finally I thought about storing the playlists on an attached USB drive, but USB drives are named in the /mnt/MPD/USB folder. Is there a way to access the only USB drive currently mounted (I'll only use one at a time) in Arch Linux ?
Pir
Re: Play podcasts ?
Postby hondagx35 » 10 Dec 2016, 15:01
Re: Play podcasts ?
Postby Pir » 11 Dec 2016, 20:09
Thank you for your help, that works.
Now I'm trying to update the feeds automatically on reboot with crontab, but that's another story...
Pir
