Playback stops and play again from beginning
ODROID related support
Postby garryman » 04 Sep 2017, 21:23
Hi, I have a strange problem and I don't know what to do.
Playback stops and play again from beginning after about 10 - 12 seconds.
This problem appears when I try to play flac 24 bit 96 kHz or mp3 24 bit 44.1 kHz, but flac 16 bit 44.1 kHz and another mp3 24 bit 44.1 kHz plays good.
I use Odroid-C2 and HiFi Shield 2. If I change Audio Output Interface to Odroid-HDMI I have the same problem.
My debug info
I cut out some of the information from the middle, because text more than 512 Kb.
garryman
Re: Playback stops and play again from beginning
Postby hondagx35 » 04 Sep 2017, 23:22
Postby garryman » 05 Sep 2017, 20:55
Hi, hondagx35
I disabled mpd-watchdog and now all files play good, thank you very much!
May be you can tell me for what this daemon need for?
garryman
Return to ODROID
