Playback stuck on paused
Postby IanD » 03 May 2015, 08:51
New to RuneAudio, installed 0.3 beta image on to Raspberry Pi 2.
No problems with installation, music source on USB hard drive attached directly to Pi.
Problem is when files are queued to play, they are stuck on paused.
Any suggestions would be appreciated
Ian
IanD
Re: Playback stuck on paused
Postby hondagx35 » 03 May 2015, 12:09
Postby IanD » 03 May 2015, 16:37
IanD
Postby ACX » 04 May 2015, 01:30
Hi IanD,
It seems like you have an output problem. Go to Menu > MPD and switch to the right output interface. If it's already selected, switch to something else and then switch it back, it should do the trick.
[SOLVED]: Playback stuck on paused
Postby IanD » 04 May 2015, 03:07
IanD
Users browsing this forum: Majestic-12 [Bot] and 3 guests
