Playlist Issue Again
Postby Hwrd69 » 08 Apr 2020, 17:56
Thanks for any responses and assistance.
RPI4
RuneAudio+R e3
Hifiberry DAC +Pro
Samsung T5 500GB SSD
Hwrd69
Re: Playlist Issue Again
Postby cmh714 » 08 Apr 2020, 18:39
I agree that the playlists are in /srv/http/data/playlists....
On your issue with a playlist of .m3u's, I believe it is the same as the issue I have with a list of Web Radio stations.....the script is NOT parsing the playlist properly and it shows as NULL. My playlists with just songs (or albums) does work properly since the script parses it properly. I tried to fudge a playlist in the json format but so far wasnt able to get it right :)
if you look at /srv/http/bash/convertplaylist.php (I think since I am not looking rn), you can see it doesnt handle playlists other than those with separate songs correctly.......at least that is what I believe HTH
Postby Hwrd69 » 08 Apr 2020, 22:05
RPI4
RuneAudio+R e3
Hifiberry DAC +Pro
Hwrd69
Postby cmh714 » 08 Apr 2020, 22:47
Well then I guess you are not running the e3 version :)
Postby hondagx35 » 09 Apr 2020, 08:37
Postby janui » 09 Apr 2020, 08:56
Hi Hwrd69,
As Frank says some of the plugins depend on the version of MPD. There have been issues in the past, specifically with m3u. If Frank's suggestions work you can automate the inclusion of the extra plugin's, see here: runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532-130.html#p26218
Postby rern » 09 Apr 2020, 12:02
Postby Hwrd69 » 11 Apr 2020, 14:36
RPI4
RuneAudio+R e3
Hifiberry DAC +Pro
Hwrd69
Postby Hwrd69 » 11 Apr 2020, 14:47
RPI4
RuneAudio+R e3
Hifiberry DAC +Pro
Hwrd69
