Playlist question
Playlist question
Postby washburn_it » 31 Dec 2015, 13:29
is there a way or a setting (even if I didn't find it) so that when I turn on the Rune-server the current track of the playlist is the last played before it was turned off?
I noticed that everytime it starts, the playlist currently loaded starts (again) from the 1st track.
Thank you, regards and Happy New 2016.
Roberto
washburn_it
Re: Playlist question
Postby hondagx35 » 31 Dec 2015, 14:42
Postby washburn_it » 01 Jan 2016, 18:52
Thanks Frank, I will try to enable that option.
Happy new year.
Roberto
washburn_it
Postby washburn_it » 02 Jan 2016, 14:00
That option is already enabled but it didn't work the way that is expected.
It's installed on a B+, maybe is a bug of the release for that version of PI?
May I do something?
Regards,
Roberto
washburn_it
Postby Beelzebassie » 02 Jan 2016, 17:59
I also have a B+, and the feature works as intended; maybe some hick-up in write permissions?
Beelzebassie
Postby washburn_it » 02 Jan 2016, 19:28
I could try to disable, save and then enable and save to see what happens...
washburn_it
Postby hondagx35 » 03 Jan 2016, 00:37
Postby washburn_it » 03 Jan 2016, 12:13
Could I delete that file so that it is recreated?
washburn_it
Postby hondagx35 » 03 Jan 2016, 12:46
Postby washburn_it » 07 Jan 2016, 12:22
I didn't try to delete the file (to try this I have to dismount everything from the car) but I tried:
- to turn off from the Rune GUI while playing the playlist
- to stop the playlist and turn off
in both situations, after the reboot, the playlist started from the 1st song so, for a reason that I don't know, it seems not to save MPD data or, if data are saved, not to load saved data.
Volume level is correctly restored after a reboot but I don't know if that value is saved into the same file.
Is there other tests that I can do?
Regards,
Roberto
washburn_it
