PLEASE SACD ISO SUPPORT.
Postby doors.sl » 05 Jun 2016, 16:02
Please include SACD ISO support in Runeaudio.
Archphile already has support, look this: http://archphile.org/blog/experimental- ... o-support/.
Im tested and this worked very good in archphile.
Please develop something similar to the Runeaudio . For this is the best version of audio that have tested for raspberry pi.
Thanksss!
doors.sl
Re: PLEASE SACD ISO SUPPORT.
Postby hondagx35 » 05 Jun 2016, 22:51
mpd-rune-0.20-1-armv7h.pkg.tar.xz.zip
(272.36 KiB) Downloaded 602 times
Postby doors.sl » 06 Jun 2016, 19:58
I installed the version that you recommended and when access SACD ISO file , does not display the songs and i dont play the file.
By upgrading my system it is normal functional, but still can not play discs in ISO SACD.
In Archphile i followed this step by step: http://forum.archphile.org/viewtopic.php?f=15&t=145 and i can play ISO SACD files normally.
Have you any other ideas of how to make it work in Runeaudio?
Thanks for help!
doors.sl
Postby hondagx35 » 06 Jun 2016, 21:24
Hi doors.sl,
did you rebuild your library?
Sorry, but this is all i can do at the moment.
Postby doors.sl » 10 Jun 2016, 14:23
I rebuild my library, but when i access ISO FILEs (SACD) can not execute them.
The system does not display the tracks.
If anyone could help me would be very grateful .
doors.sl
Postby doors.sl » 16 Jun 2016, 16:59
Every time I restart my RuneAudio it automatically reconfigures my mpd.conf file.
It is to disable this automatic configuration?
Because to run the SACDISO must be included in mpd.conf the some commands.
Thanks!
doors.sl
Postby judo » 25 Jun 2016, 08:47
Hi all,
I wanted to cast a vote for sacd-iso support for a time.
doors.sl the automatic configuration was the problem, is it working now ?
judo
Postby doors.sl » 27 Jun 2016, 20:02
Unfortunately is not working SACD ISO in Runeaudio .
To solve the problem I ended up giving up use RuneAudio and moved to the Archphile .
In Archphile SACD ISO works perfectly.
doors.sl
Postby judo » 29 Jun 2016, 22:42
Thanks.Then I should try Archphile too.
judo
Postby frengo » 04 Oct 2016, 00:35
frengo
