tonight I have done further testing with a Synology NAS using SMB/CIFS and NFS.
When I use SMB/CIFS, the NAS share gets mounted properly with owner 'mpd', updating the library starts immediately.
Using NFS causes the mount to be done as 'root' and this is where it goes wrong. On the server I could map root to admin or guest, root would have access, bus this does not help. RuneAudio uses mpd to access the share and that will only work if the share is mounted with 'mpd'.
Now, I could map all users to admin, but that is kind of dirty and should not be done.
Is it a known problem, that root is used to mount NFS shares?
Gé
