Port Runeaudio to Odroid C1 (Arm v7)
ODROID related support
Re: Port Runeaudio to Odroid C1 (Arm v7)
Postby hondagx35 » 12 Aug 2015, 23:13
Hi all,
ODROID C1+ and hifi shield:
Postby ACX » 12 Aug 2015, 23:28
Postby hondagx35 » 13 Aug 2015, 13:56
Postby ACX » 13 Aug 2015, 14:04
I like a lot all this interest from HardKernel for the Hi-Fi applications of their new board :)
Postby jazzaj » 13 Aug 2015, 14:53
It's time to change my RPI2 for a new board... ;)
Odroid C1+ (/regulated linear PSU) > Audio-gd NFB-1 (with Amanero384 combo) > Audio-gd Precision 2 > Triangle Lyrr 222
jazzaj
Postby gkkpch » 13 Aug 2015, 16:50
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Postby zagtastic » 13 Aug 2015, 19:06
just wish that the hifi shield had a low-noise/low-impedance standard headphone out in addition to the line out 3.5mm :(
oh, and a case with the proper cutouts.
zagtastic
Postby gkkpch » 13 Aug 2015, 19:51
gkkpch
Postby Tinitus » 13 Aug 2015, 20:53
cool that the C1+ is out. Given the fact that I do not use I2S so far no real reason for me to upgrade but still nice to know that Hardkernel listens to the Audio-Geeks. By the way who needs a case? I like my solution better:
http://www.aktives-hoeren.de/viewtopic. ... 4&start=45
Best Regards
Uwe
Tinitus
Postby eRsil » 13 Aug 2015, 23:03
Thank you very much, Frank, for this port. It's the best image for Odroid C1 that I've tried, but I have some questions.
When I add some cue file to the Queue of RuneAudio everything is OK - I can see all songs separately. But when I add any folder with some flac/ape and cue files I can see only one flac/ape file in the Queue. It's not a problem if I want to add one album, but a big problem if I want to add all discography of some band.
And 2nd question - when I'm listening mp3 files or web radios program says that they are 24 bit instead 16 bit, but it's everything correct with flac, ape and alac files.
What can I do?
Thanks and excuse me for my English.
eRsil
Return to ODROID
