Port Runeaudio to Odroid C1 (Arm v7)
ODROID related support
Re: Port Runeaudio to Odroid C1 (Arm v7)
Postby Tinitus » 19 Jan 2016, 19:33
it probably does not surprise you, commenting the line which served to mount the eMMC did the trick, now I have got one C1 in order to listen to music and one C1 in order to tinker with pipe out to sox and/or brutefir. If I make any progress I will report.
Best Regards
Uwe
Tinitus
Postby hondagx35 » 20 Jan 2016, 23:32
Hi Uwe,
great to hear that you were able to fix this.
Postby davidevinavil » 02 Feb 2016, 09:26
Hi Frank, I would to compile kernel for odroid c1+ to change blue led stuff. I have to use hard kernel source for arch Linux or there are other source for rune audio? Thank in advance
Davide
davidevinavil
Return to ODROID
