Port Runeaudio to Odroid C1 (Arm v7)
ODROID related support
Re: Port Runeaudio to Odroid C1 (Arm v7)
Postby hondagx35 » 26 May 2015, 22:03
Postby Tinitus » 26 May 2015, 22:34
again thank for your quick answers. As far as I know C1 has no I2S, but I am not sure.
Just checked the wifi settings, my router tells me its IPv4 (is that Network/DNS?), cmd tells me that IPv4 of Network and DNS are the same, so there should not be a problem. But I lost connection again. I had wifi and Ethernet plugged into the device and was able to puTTy into it via Wifi in order to have a look at /etc/netctl/. Funny thing is that I did also loose the connection via Ethernet. My router tells me that both connections (Wifi and Ethernet) are still working. Strange
Good night
Tinitus
Cool about the IR
Tinitus
Postby hondagx35 » 26 May 2015, 22:41
Postby gkkpch » 26 May 2015, 22:45
Hi Frank, Tinitus,
thanks for what has been done already. I hope to get my C1 by the end of the week and will contribute in testing as soon as I get my hands on it.
The C1 does not have I2S exposed to any pins, so the only options are HDMI audio or usb audio.
Gé
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Postby hondagx35 » 26 May 2015, 23:07
Postby gkkpch » 27 May 2015, 12:14
yes, but is that not your normal HDMI audio out?
Gé
gkkpch
Postby Tinitus » 27 May 2015, 20:35
here we go:
http://pastebin.com/HLV4A5dX
There were some strange messages concerning the wifi connection but I do not understand them. I edited ip addresses an network name. Do not want to make those public.
This time I connected via wlan0 only. Did the debug thing with Paste etc. started playback and shortly after, before I could log another debug the connection went. Could not get a connection again neither through the ip address by laptop or iphone nor through ssh or runaudio.local. via the iphone, just tried it know (30 min later). My router tells me he still has a connection with the C1 under the ip address I first contected tom and cannot get a connection know.
Hope this helps solving the mystery (at least it is a mystery to me)
Greetings Tinitus
Tinitus
Postby thanhvo31 » 27 May 2015, 21:12
Sadly I got not bootable! I try several uSD card !
And here is my MD5 hash for 0.img 10e01974ef35a14539d0e7388747ecd8
thanhvo31
Postby hondagx35 » 27 May 2015, 21:29
Postby thanhvo31 » 27 May 2015, 21:50
thanhvo31
Return to ODROID
