Port Runeaudio to Odroid C1 (Arm v7)
ODROID related support
Re: Port Runeaudio to Odroid C1 (Arm v7)
Postby Tinitus » 29 May 2015, 19:54
Tinitus
Postby Tinitus » 29 May 2015, 19:59
Tinitus
Postby gkkpch » 29 May 2015, 20:02
removed pulseaudio.
I also tried the git pull, but it obviously failed.
I'm still having trouble with HDMI output and the network problems hav not disappeared either.
Did the git pull not work? I will check again...
@Tinitus: have to check your post, all went to fast here :)
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Postby gkkpch » 29 May 2015, 20:10
gkkpch
Postby hondagx35 » 29 May 2015, 20:16
Postby gkkpch » 29 May 2015, 21:47
I need to look into this tomorrow, I did not see any difference yet.
The error messages on git pull has gone, but otherwise things are still the same.
Sorry I have quit for today.
gkkpch
Postby Tinitus » 29 May 2015, 22:51
the git pull worked for me, meaning the update was done. I have no HDMI cable so I cannot check whether I get HDMI audio. I installed a Ramdisk in a subfolder under local storage and made a second partition on the SD card as well which I put in a seperate subfolder under local storage. Works a treat. I prefer RuneAudios visualisation of the different storage devices. I know have configured RuneAudio exactly like I want it to be :D .
But hey, mpd pipe out? and brutefir
Frank the files (better the links) you posted on page:
the-new-4-core-raspberry-pi-t862-150.html?hilit=Quadcore%20pi
are the ones I need in order to do this if I am correct?
I would transfer them to the C1 via Filezilla and then use pacman -U in order to install them right?
If I wanted to use only one filter in brutefir in order to avoid loading different filter files in console I would need to up/downsample music files. I do not want to dothis with mpd but preferably with sox. Then I would need to pipe out first to sox and then to brutefir and then into the DAC. Is sox already in the RuneAudio image for C1.
Again many thanks for the nice work Frank and special thanks for also caring for particular user problems as the driver problem with my wifi dongle
Good night
Tinitus
Tinitus
Postby hondagx35 » 29 May 2015, 23:24
Hi Tinitus,
nice to hear that it works.
Take a look in the root folder of your device!
Sox is installed.
Postby thanhvo31 » 30 May 2015, 08:16
thanhvo31
Postby hondagx35 » 30 May 2015, 09:45
Return to ODROID
