Port Runeaudio to Odroid C1 (Arm v7)
ODROID related support
Re: Port Runeaudio to Odroid C1 (Arm v7)
Postby gkkpch » 09 Jun 2015, 20:35
Odroid-C1+, 8Gb eMMC, 8Gb µSD with 32bit/384Khz Odroid-C1+ HiFi shield (PCM5102)
Odroid-C1, 8Gb µSD with DAC: XMOS 384K/32bit USB (PCM5102)
Other: 24bit/192Khz Audiophonics DAC Sabre ES9023 I2S
gkkpch
Postby Tinitus » 09 Jun 2015, 21:23
all my 24 bit .wav files play without any problem via the C1 to my Audio GD (PCM1704UK). I don't think it is a problem of C1 not being capable of 24 bit. Maybe it is something to do with the USB implementation in that particular DAC.
Best Regards
Tinitus
Tinitus
Postby gkkpch » 09 Jun 2015, 21:46
Hi Tinitus,
yes, seems so.
Comparing C1 and X2 was not quite correct though, but an indication that it is not the FIIO itself either.
Because C1 and X2 have different kernel versions, they probably have different driver versions too.
gkkpch
Postby gkkpch » 09 Jun 2015, 22:26
gkkpch
Postby thanhvo31 » 11 Jun 2015, 12:50
thanhvo31
Postby hondagx35 » 11 Jun 2015, 15:29
Postby gkkpch » 11 Jun 2015, 17:39
gkkpch
Postby gkkpch » 11 Jun 2015, 19:01
gkkpch
Postby hondagx35 » 11 Jun 2015, 20:52
Hi Gé,
we only things you have to do is:
- get a config file for your remote
- adapt the lircrc configuration (nano /etc/lirc/lircrc)
- enable lircd (systemctl enable lircd)
- enable irexec (systemctl enable irexec)
as i described .
Normally you can record your own configuration file with lirc on the device.
This does not work on Arch Linux Arm.
So you have to get a premade config file for your remote.
Postby gkkpch » 11 Jun 2015, 20:55
Found the problem and created a new lircd.conf as a fix for an MCE remote, need a bit of time to consolidate and test.
gkkpch
Return to ODROID
