Power Supply – Power Bank
Re: Power Supply – Power Bank
Postby PeteB » 16 Apr 2016, 15:37
Postby rastus » 16 Apr 2016, 16:20
rastus
Postby PeteB » 16 Apr 2016, 16:47
Must have looked at a different one, sorry. This one, with the toroidal transformer, rectifier and filter, sold as a "switch mode adapter upgrade"?
(picture on green background)
edit:
and here, for £ 195.00? Clearly described as a "Raspberry Pi Linear Power Supply - by Sbooster"
Postby dunghnguyen » 16 Apr 2016, 19:39
It is so expensive against to RP2 price :(
dunghnguyen
Postby dunghnguyen » 17 Apr 2016, 02:07
I tried 2 cases:
1) switching adapter Asus 5VDC, 1.35A
2) Power bank battery Asus 9600mAh, 2.4A
Both 2 cases run well. No any signal that lacks of power. But my ears recognized the case of battery the sound is clearer, more detailed, the sound stage looks full, more confident.
Looking around options for a linear power supply that its price seems extremely high against to what the ears can get. I think the sustainable way is to invest for a toroidal transformer with filter to supply power for my amp (Denon 720ae, it is normal EI transformer) that this solution I could diy at the cost of linear power for RP2 that many tried / got better results.
dunghnguyen
Postby rastus » 17 Apr 2016, 02:21
dunghnguyen > The previous page, and pages, of this thread does have a lot of information and recommendations (with links to further reading), both low and high priced, from many people (other than myself).
Edit: Including a link comparing both the El transformer against the Toroidal transformer. Also, the design and addition of newer low noise technology applied to SMPS's. A lot of good reading from many people in this thread.
rastus
Postby dunghnguyen » 18 May 2016, 16:17
This one is 50VA, out 9VDC-3A looks too much for my DAC (9VDC-1.3A) so I intend to add in 1 additional linear rectifier/regular board to have another out 5VDC-2A using for Pi 2/C2
dunghnguyen
Postby uimitechnology » 20 May 2016, 12:39
if you want to buy power bank look our uimi power banks with high battery capacity support ....uimitech.com
uimitechnology
Postby LC1 » 22 May 2016, 09:26
LC1
Postby PeteB » 22 May 2016, 13:25
Something like the ipower will not help if you have noisy mains and/or bad grounds (earth connection). Neither will a conventional linear supply. For that you would need a large isolation transformer($$$), and/or large line filter($$) inline with the mains before the power supply. Or that battery bank (least expensive).
None of that including a battery bank will stop noise from the ethernet cables or (in my case) the HDMI cable.
As you said yourself, ethernet "might be" a source of noise, but it does not mean it "will be" a source of significant noise in your case (or anybody's). For me personally, "might be" is not a reason to spend several hudred dollars on power supplies. Especially since a WiFi dongle can fix that for $10.
With just a single connection to an audio system (WiFi instead of wired ethernet, no HDMI, no powered USB hub), and a stock 2A supply, my Pi2/DAC+ combination has very low noise, and extremely low distortion (also assuming volume control disabled), even with poor mains power.
In the test above, with a less-than-perfect 1KHz test signal, 48K sample rate, 16-bit resolution, harmonics peak at -100db and noise is down around -110. That is almost studio quality sound.
When I start adding other things, and other connections, the noise goes up, and eventually becomes audible. No power supply can prevent that.
Neither a linear supply nor a better smps will prevent noise from the ethernet cable, or the HDMI cable (something I recently found out while testing).
Don't get me wrong, I am a big believer in clean power, and I used to design and test power supplies as part of my job. I could go on and on about the benefits of good power supplies in audio, but the fact is that you get most of the same benefits from simple and cheap solutions.
