Power supply with both 12v 5a and a usb charger for project
Postby Kode » 10 May 2015, 14:54
I currently use runeaudio with a rasperry pi and some active speakers in my sons room to play audiobooks at night.
I've decided to try creating a 1 box solution.
The only issue I have is I'd like to have just a single lead going to the box, but I need to power the TA2020 amp AND the raspberry pi, so what I think I would need is something that could provide 5a at 12v for the amp and 2a at 5v for the pi, does such a thing exist? I guess the simple (but crappy) alternative would be to put an extension lead inside the box and just run 2 seperate plugs off it.
Does anybody have any suggestions?
Kode
Re: Power supply with both 12v 5a and a usb charger for proj
Postby Kode » 10 May 2015, 17:38
Would something like: http://www.dx.com/p/t60-5-12-12v-5a-5v- ... U981fnF-So work?
If it would, would I need to do something to reduce the 8a from the 5v supply?
Kode
Postby J@r0d » 10 May 2015, 18:10
This power supply contain inverter and inverter is not good with use DAC, exception for specialy power supply with hash voltage at 300Khz
But for Digi output this powersupply is good
J@r0d
Postby Kode » 11 May 2015, 07:51
Well to begin with audio will just be from the built in jack on the pi, but eventually I would probably add a DAC, so if that supply is no good for that are there any other options?
Kode
Postby Kode » 11 May 2015, 10:44
Would using something like http://www.monacor.co.uk/products/carfi ... nr/212420/ between the pi and amp help at all?
Kode
Postby ChiiFii » 17 Jun 2015, 18:49
I've build a System like this and now i've got some interference noise.
Is there any solution for killing them? Maybe with a cap?
ChiiFii
Return to DIY and tweaks
