Problem after Static IP is setup
Postby odiofil » 15 Jun 2015, 23:06
Hi, This is my first time with runeaudio. I have PI B and running 0.3-beta. I am facing some issue to connect to web ui in some circumstances.
No problem for installing runeaudio and first connection, I can navigate, set I2S digi and couple of options, add a NAS mount and manage webradios.
I can shutdown or reboot the system.
I get problem when setting a static IP : after reboot, runeaudio.local and/or IP are no longer accessible.
Any idea on what is wrong with installation or setup.
Thank you
odiofil
Re: Problem after Static IP is setup
Postby JoergZ » 17 Jun 2015, 08:46
JoergZ
Postby frengo » 20 Jan 2016, 12:30
Hi, I run Odroid version of RuneAudio (on an Odroid C1+, obviously) and I need to reach the device (and UI) from the Web.
How I can to do this ?
Thank for suggestions.
frengo
Postby hondagx35 » 20 Jan 2016, 22:42
Hi frengo,
you have to give your Pi a fixed IP address and forward port 80 on your router to this IP.
Please search the web for this topic.
Something like should help.
Postby frengo » 26 Jan 2016, 01:29
frengo
Postby hondagx35 » 26 Jan 2016, 07:10
