Problem - UI is available from outside
Postby dror » 18 Dec 2015, 10:49
I have set my Rpi2 with RA. I dont have a router so my entire home machines are connected to one switch, which is connected to a cable modem.
The problem is, when I set my android browser to the Rpi IP, I get to the RuneUI, even when I am not connected via my local Wifi, just from the cellular network no matter where I am. This means anyone can set to that IP get access.
How can I prevent this?
Thanks..
dror
Re: Problem - UI is available from outside
Postby hondagx35 » 18 Dec 2015, 12:57
Postby dror » 18 Dec 2015, 14:39
It is names ARRIS
cant tell the model though..
guess I need to hang up the Rpi now... :)
dror
Postby nic » 19 Dec 2015, 13:16
Surely you must be hanging off the wifi ? I don't think you can vpn in without dynamic dns , besides that if you are accessing using a class C ip , it can't be from outside your network . Your best bet is to walk a few hundred yards down the road and retry :)
Nic
nic
Postby dror » 19 Dec 2015, 18:39
Hmm well.. I was maybe 8 km away. And doubled checked now from home. When wifi off, I can access RuneUI.
this seems to be a serious problem.
My setup is :
Cable modem
Switch ---------- PC (connected to switch)
------------------- Rpi (connected to switch) --- Wifi dongle(AP)
dror
Edit: one thing I can think of (not sure if its related) is that I kill "wpa_supplicant -B" pid on startup in order to make my AP accessible.
dror
Postby utschu » 20 Dec 2015, 13:45
I don't know of anybody who connects it's devices neither directly nor via switch behind a cable modem, as you would leave doors and windows wide open for any suspecious individuum tryind to get into your system.
This could only be brought to a higher risky level by posting the IP address somewhere in a forum.
I wonder wy millions of poeple are buying routers if they are not needed at all.
utschu
Postby Beelzebassie » 20 Dec 2015, 14:07
Back in the days, more than 10 years ago, I had a similar setup:
2+ computers with spoofed MAC-addresses (all identical) connected to the internet through a switch connected to a cable modem. Never had any problem whatsoever... The domestic adaptation of WiFi has made routers commonplace, and I would indeed not recommend a switch-only setup nowadays.
Beelzebassie
Postby dror » 20 Dec 2015, 18:05
Isn't my OS level firewall supposes to prevent those intrusions? (for the PC machine)
I have check with online tools and it seems I'm protected...
Edit:
checking
iptables -L via ssh, it seems all policies are set to "ALLOWED"
dror
Postby dror » 22 Dec 2015, 08:26
well..
no one of the devs cares Runeaudio receives connections it should have dropped !?
dror
Postby schinken » 23 Dec 2015, 16:59
Easiest solution is to get a cheap router and divide your home network from the outside world.
schinken
