Problem with IQ AUDIO DAC PI DIGI AMP+
Postby KENMAC » 21 Apr 2018, 21:02
On setting this up I can see my NAS box and I have managed to build my library, but I cannot get any sound. In MPD settings/Audio out I can only select from Rasperry Pi Analog out or HDMI out. There is no IQAUDIO PI DAC I2S.
Help
Ken
KENMAC
Re: Problem with IQ AUDIO DAC PI DIGI AMP+
Postby janui » 22 Apr 2018, 13:46
Hi KENMAC,
This setup will work fine, but the solution depends on the image which you are using. Could you post your debug or at least the first 30 lines or so from the debug screen.
Postby KENMAC » 23 Apr 2018, 17:35
Hi I now have this working. I had downloaded the latest beta, but it doesn’t work out of the box on the DigiAmp. I needed to add a line to the config. txt to unmute it. It took a lot of searching to find the resolution though.
KENMAC
