Problems installing Rune in Rasberry Pi 3B+
Re: Problems installing Rune in Rasberry Pi 3B+
Postby carlmart » 18 Aug 2019, 19:14
I am carlmart. I didn't give any instructions.
carlmart
Postby hondagx35 » 18 Aug 2019, 21:56
sorry.
See here problems-installing-rune-in-rasberry-pi-3b-t6878.html#p28344
RuneAudiois mainly designed as a headless player, the local display is an option.
Postby carlmart » 18 Aug 2019, 22:49
Whatever it was designed for, even if to work headless, the program should run on the Raspberry and it does not.
Why it does not run here?
carlmart
Postby hondagx35 » 19 Aug 2019, 11:12
Please try again the image from this link:
runeaudio-0-5-beta-for-all-raspberry-pi-models-t6532.html
Postby carlmart » 20 Aug 2019, 15:39
Thanks, Frank!
I will try them. Let's hope they work.
I still do not understand why I can't open the WEB Runeaudio interfaces. Do I need to run the program in the Raspberry first?
carlmart
Postby AndyF » 20 Aug 2019, 16:07
Or you can try this image with extended UI and much more options:
Or you can wait a few days - there´s a big update from rern for extended UI in progress.
Andy
AndyF
Postby carlmart » 22 Aug 2019, 03:18
http://runeaudio.local/ continues to be off line.
So I can't try installing Rune Audio.
carlmart
Postby AndyF » 22 Aug 2019, 04:41
In my case ".local" don't work. Try instead.
Regards, Andy
AndyF
Postby Beelzebassie » 22 Aug 2019, 09:29
What IP has your router given RuneAudio? You can use that to browse.
Beelzebassie
