Question re: volume control and bit-perfect playback
Postby kapusta » 23 Jan 2018, 18:04
kapusta
Re: Question re: volume control and bit-perfect playback
Postby hondagx35 » 23 Jan 2018, 19:00
Hi Kapusts,
your findings are correct.
Disabled means that volume can't be changed is set to the last level.
We decided to implement it in this way do not kill your loudspeakers while setting volume to disabled.
Setting hardware volume to 100% and then disable it should give you a bitperfect config.
Postby cmh714 » 23 Jan 2018, 19:41
Yes for bit perfect the Volume needs to be disabled.
To increase your volume since it sort of sounds like its low (and I had this issue initially), look into alsamixer settings.
You can get there via your web browser: Your_IP:8080 should work. You can also ssh into the Pi and do it as well.
GL.
Postby hondagx35 » 23 Jan 2018, 21:33
Postby kapusta » 23 Jan 2018, 22:52
kapusta
Postby hondagx35 » 23 Jan 2018, 23:15
Postby kapusta » 24 Jan 2018, 02:39
kapusta
Users browsing this forum: Google [Bot] and 3 guests
