Radio station lists
Suggest the music you love
Radio station lists
Postby ianhaynes » 11 Feb 2016, 15:48
Just found two good resources for radio streaming urls.
For UK commercial stations:
For world wide stations:
In the first instance you can use the M3U stream address and delete the .M3U off it. Most seem to be 16bit 44 kHz feeds although there are some 24 bit ones.
For the second list you need click through to the station details and then see if the feed link is usable. Some need .M3U taking off as above, others work as they are.
Pi 2, Ver. 0.5b, IQAudio DAC+
ianhaynes
Re: Radio station lists
Postby hondagx35 » 11 Feb 2016, 16:13
Hi ianhaynes,
thank you for the links.
Have you ever tried Dirble?
Dirble has listed most of them.
By using Dirble there is no need to tweak URLs or extract them from playlists.
Postby ianhaynes » 11 Feb 2016, 16:31
Yes I have tried Dirble but the UK stations aren't there and lots in the other list aren't there either.
There are so many that no directory is going to cover everything.
Ian
ianhaynes
Postby Discovery » 08 Mar 2016, 22:19
Finally, BBC Radio 4 on my Pi!
Thanks Ian :)
Discovery
Postby YannM » 21 Apr 2016, 12:59
Here is a small trick to find the url of a radio station not in the database.
Go to the webpage playing the radiostream with Chrome and display the source code of the page (Ctrl+U) and search (Ctrl+F) for a ".mp3" in the code. Usually there is at least one url (if two or more, check the bit rate of each).
Best,
Yann
System: HD -> Wifi -> Pi 3 -> Audiophonic I-Sabre V3 -> Cambridge Audio
YannM
Postby leinadhok » 03 Jul 2016, 02:10
leinadhok
Postby rikardo1979 » 13 Jul 2016, 21:03
list of some very cool and HQ radios
My top favorite is Audiophile Live ;)
Enjoy
rikardo1979
Postby leinadhok » 14 Jul 2016, 05:51
leinadhok
Postby ghudson621 » 29 Jul 2016, 08:04
Thanks for the links. Finally I've got it :)
ghudson621
Postby ronfa » 31 Oct 2016, 08:01
che noia essere ricchi! :)
ronfa
Return to Listening to / Recommendations
