Raspberry 2b USB ethernet config
Postby smitec » 11 Jun 2019, 09:53
Hi all,
I'm using a raspberry pi 2b for Rune Audio.
I try to connect an USB to Ethernet device (do want to use the internal ethernet, because the RPI will be build in and only USB is lead outside.
Can someone explain me how to configure the USB-ethernet card, I can not figure it out.
I tried to copy eth0 to eth1 in /etc/netctl (and edit the file into eth1), and I see the eth1 gets an IP adres,
but when I disconnect eth0, the connection drops.
regards,
Chris
smitec
