Raspberry Pi 2 and Wifi issue
Postby sito01 » 17 Aug 2015, 20:01
Hi all,
Hopefully someone can help me!
I have a respberry pi 2 and a edimax EW-7811Un wifi usb. V0.3-beta running
I can hook up everything fine with the cable connected. The wireless setting look good and I am connected to the hidden SSID wifi network.
I can ping the respberry and it responses.
The rune GUI is working fine till I disconnect the LAN. There is no chance to get the GUI running. I still can ping the Wifi!
Didn't find a topic on that issue!
I hope someone has a solution to that problem?!
stefan
sito01
Re: Raspberry Pi 2 and Wifi issue
Postby hondagx35 » 17 Aug 2015, 22:03
Hi Stefan,
did you try it with http://runeaudio or with the ip (e.g. 192.168.0.100)?
Did you try to shutdown with both active and then restart with cable disconnected?
I'm asking, because avahi has problems then you hot-plugging the cable.
Postby sito01 » 18 Aug 2015, 06:19
First, I tried with runeaudio, that didn't work and then I was using the ip, also not working.
It was connected with both on, then I shout down, disconnected the power and LAN. Then I powered the device up.
I did that a couple of times, but it didn't change anything.
BUT today I powered up the device without LAN and it worked somehow?! I could connect via IP, runeaudio was not working.
I don't know why, I will test today when I am back from work!
Stefan
sito01
