raspberry pi disconnecting its self from the network
Postby charleskelly » 24 Mar 2015, 20:25
ok, so i have rune audio set up on a raspberry pi to play music from a nas server (a raspberry pi 2 is used for this). The raspberry pi is connected to the network via wifi dongle. Quite frequently, I'll go to access the UI, and chome will throw, website not available. Ive tried accessing both the ip, and runeaudio.local along with hard refreshes (ctrl+f5). SSH also appears offline. If i plug in a screen and keyboard to the rune audio pi, I try restarting from the command line (shutdown -r now), the pi reboots but the webpage is still offline. The same happens if i shutdown fully (shutdown now), remove the power cable and re power the pi. the ui still appears offline. So far the only way of solving this is to restart my router. Note my laptop is not having this issue either and that is also on wifi. Is this a problem of my own, or a problem within rune? Any suggestions? Thanks.
charleskelly
Re: raspberry pi disconnecting its self from the network
Postby unameme » 25 Mar 2015, 09:08
That's not guilt of Runeaudio or rspberry, but your router.
I run Rpi2 with Rune for over a week(did not restart it once) and it's still running wery well.
unameme
Postby charleskelly » 25 Mar 2015, 19:14
charleskelly
Postby unameme » 25 Mar 2015, 20:17
Mine is connected by edimax wifi dongle,
unameme
Postby nopphong » 26 Mar 2015, 16:45
Mine is if i use pi 2 for a long time(over night) (i use firefox) i will cannot control via http://runeaudio . I have to input ip address like 192.168.1.31 and it work fine.very strange .
nopphong
Users browsing this forum: No registered users and 88 guests
