Raspberry Pi download file
Postby nic » 14 Feb 2014, 14:06
Comes through with a .gz extension . Instructions suggest this should come through as a .zip file . How do I get this onto the SD card ? I'm using a PC for the download
cheers
Nic
nic
Re: Raspberry Pi download file
Postby ACX » 14 Feb 2014, 14:31
Hi nic, I'm sorry but I didn't have the time to update the docs. You can open the file and extract the .img file with as told in the guide, or you can simply use . With the last one you don't need to extract the .img file, you only have to select .tar.gz from the dropdown option menu before picking the downloaded file.
Postby nic » 14 Feb 2014, 23:45
Splendid ! It's working after using that 7zip unpacker . Up and streaming from the NAS within five minutes . Will do some listening tomorrow :)
cheers
Nic
nic
Postby ACX » 15 Feb 2014, 01:43
Good, let us know how it sounds :)
Postby nic » 15 Feb 2014, 10:35
Yes , will put Rune through the mill once I have use of the front room :) So far have tried Raspyfi and Volumio and found Raspyfi the most stable , Volumio had a few crackles here and there . I did not notice any discernible difference in sound quality between the two . Have identified Kingston 8GB SD4 cards are problematic in the Pi which I believe was causing the issue I reported here a while ago . Sandisc cards of the same spec work fine .
cheers
Nic
nic
