Raspberry pi installation problems
Postby audioeng123 » 14 Jan 2019, 20:52
Hello all,
I have a raspberry pi 1 B+ that I'd like to install rune audio onto, however I am running into problems when installing it. I downloaded the latest image of rune audio for the B+, flashed an SD card up using etcher (also tried with win32discimager) and all I get upon powering up the rpi is a blank screen with the ACT light on the pi solidly lit. I have tried all of the older versions of rune audio and still have no luck at all. I have ruled out the SD card and the pi itself by installing NOOBS onto it which works absolutely fine so I'm feeling quite stumped by this one as you can imagine! Any suggestions on what to try next would be great. Thanks :D
audioeng123
Re: Raspberry pi installation problems
Postby eea123 » 16 Jan 2019, 12:27
Sounds like you checked on the PI 1 specs versus the Rune version you trying to use? I'm using a PI 2 B and it was 100% my first time ever using a Raspberry PI with all of the flashing the SD steps, … I was totally in the dark and it did take a reboot or two to get everything working. Others on this forum were of great help. I won't try to claim anymore knowledge than that :).
eea123
Postby janui » 16 Jan 2019, 17:41
