Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby janui » 19 Jan 2018, 13:57
Postby gearhead » 19 Jan 2018, 20:27
gearhead
Postby janui » 05 Feb 2018, 21:20
Postby hondagx35 » 05 Feb 2018, 22:00
Hello janui,
thank you very much for the work you have done.
Postby gearhead » 03 Mar 2018, 03:32
group,
I have a new Pi Zero W. I also have an image I have updated all the rune packages as well as the rest of the OS. Well, I made a copy of the image and got it going on a B+ so I could set up networking and everything. Well, It works, somewhat. I can send DLNA and shairport to it, but MPD does not run. Dmesg is not helpful. systemctl says MPD is running without errors. Keep in mind this image worked perfectly on my B+ and I took the card out and put it in the ZeroW and have my problem.
What I get in the UI is a spinning circle if I select anything in the library. If I click again, the circle goes away and I can select a song. It is this way navigating. Click, circle, click again and i can select. If I try to 'add and play', I get nothing added to the queue. If I select the queue, I get aspinning sircle on a black background. Since there is nothing in the queue, I cannot select anything. Nothing plays. I have pored through the logs and see nothing. What could cause this? I have tried updating the kernel and such. If I pull this image out and put it in a B+, it works fine.
Puzzled.
Gearhead
gearhead
Postby janui » 03 Mar 2018, 12:51
Postby gearhead » 03 Mar 2018, 17:00
janui,
Thanks for the help, but that also did not work...
I made that change and still have the same issue. Strange that it does not act like that on a B+, just a Zerow. If I plug this image in my B+ and reset it, it boots comes up and is fluid and works just fine. On the zeroW, I cannot add anything to the queue and it always has the spinning circle. Strange.
I grabbed your image and was able to make that work for me.
Is there a reason why does your image from 20180202 not start in AP mode? I flashed it and powered up my zerow and did not see any SSID from it. To get it on my network (Zeros are a pain like this... No eth0 makes it hard), I copied my netctl profile from the other image booted it with keyboard and monitor attached. Enabled it from the command line "netctl enable profile" and rebooted and it connected and came up...
Also, you may want to install sudo on the image. If you install addons from rern to this image, it will fail the last couple lines of his script as there is no /etc/sudoers.d/.
Thanks for the help. Sorry you wasted time on it for me, though.
gearhead
Postby gearhead » 03 Mar 2018, 19:46
OK, Here I am again...
I can get Janui's image going on my zerow. All good. I tried to update the UI to the 0.4b from Frank and it mostly works except the version of mpd on the image does not support soxr and mpd fails to start. I know nothing about soxr nor do I have interest in it. What I do know is that if I delete the line in the /etc/mpd.conf that references soxr, it all seems to work. Problem is that when I do that, I no longer get the UI page to edit the mpd config items... Where in the UI is this so I can delete the reference to soxr in the config? When I search on 'soxr' in all the files in /var/www 'soxr' is nowhere to be found. It must be comparing it to a file somewhere else. Even the _os/config files do not reference soxr... How does the UI know that I edited the mpd.conf file and where can I go to fix this issue?
Gearhead
gearhead
Postby janui » 03 Mar 2018, 20:18
Postby janui » 03 Mar 2018, 20:32
Users browsing this forum: Google [Bot] and 5 guests
