Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby hondagx35 » 02 Jul 2016, 09:32
Postby flega » 03 Jul 2016, 08:56
I tried to do that but with no success. I use your script, use my from my other (working) Raspi2. In neither case Zero will connect to my AP. Only difference from different scripts is that led on WiFi dongle have different blinking patterns. Is there way to produce a web-like screen on my monitor?
Low cost audio for everyday use: Raspberry Pi 2 -> USB sound card ->preamp+Low-pass Filter NE5532 ->2x TDA7492 amp -> 2 fullrange speakers + 1 bass speaker.
flega
Postby dunghnguyen » 06 Jul 2016, 16:40
If Zero can run Rune then it is best one against to others in term of price. I love to see this happening. Sorry I don't have Pi Zero but I have just read what you all in this thread did that I wish to have one to help. Thanks @hondagx35 and Rune team.
dunghnguyen
Postby flega » 06 Jul 2016, 18:14
As you can see, there is almost impossible to setup Rune on Zero if you don't have Raspi One, which most of us don't have. I have order a USB to Ethernet adapter and will try to use it with Zero.
flega
Postby hpeter » 08 Jul 2016, 07:34
hpeter
Postby hpeter » 08 Jul 2016, 09:25
hpeter
Postby flega » 11 Jul 2016, 13:34
I have tried again using yours and Frank values for Proto, group and Pairwise, also use values from my raspi2 in which Rune works regular. I make another file in /etc/netctl beside TEST and use different values for Proto, group and Pairwise. Than I use another AP (different manufacturer) with all those which I wrote here(of course, change SSID and Pass). Nothing worked, can't connect in neither way. :( :( :( :(
flega
Postby hondagx35 » 11 Jul 2016, 16:18
Postby flega » 11 Jul 2016, 16:43
There is no profile when I try to list it. There are two files in /etc/netctl - krov and test.
flega
Postby hondagx35 » 11 Jul 2016, 17:01
