Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby flega » 11 Jul 2016, 20:30
Problem solved. WiFi dongle was in one port in USB hub that don't work :( :(
I have connected it properly and now have both profile in the list. I have disabled profile Test and when I try to enable other profile get message that can't conect to a network. Double checked and try all kind of settings but can't connect to neither of my two AP's.
If network is open (no security pass) what settings will be than? I will try that if someone give me a data and that's it - I'll wait for working and tested image for Zero
Low cost audio for everyday use: Raspberry Pi 2 -> USB sound card ->preamp+Low-pass Filter NE5532 ->2x TDA7492 amp -> 2 fullrange speakers + 1 bass speaker.
flega
Postby hondagx35 » 11 Jul 2016, 21:31
Postby flega » 12 Jul 2016, 09:24
No connection even with no WPA. I give up, will use Zero as LibreElec until working image for Zero come. Thank all for help and your time!! ;)
flega
Postby flega » 16 Jul 2016, 09:25
Today I have received Ethernet to USB dongle. Connected it to a Zero and it seems that Rune don't have drivers for that piece of hardware :(
flega
Postby delboy711 » 09 Aug 2016, 20:17
delboy711
Postby Yeti » 10 Aug 2016, 20:25
Yeti
Postby dunghnguyen » 16 Aug 2016, 17:26
Hi @delboy711,
Reading your post I understood you installed Rune on Pi Zero successfully? As well as it is fine now for the LAN connection even wifi? your post dd. 10 Aug till now meant nearly a week so can you pleased confirm me it was ok as I am really curious to buy 1 for Rune playing music as this should be the best solution in term of costing? Your reply is appreciated. Tks.
dunghnguyen
Postby dunghnguyen » 17 Aug 2016, 11:46
@delboy711: I think this is the LAN board that you concerned ENC28J60 Ethernet LAN / Network Module for arduino 51 AVR STM32 LPC learning tool Network Module
dunghnguyen
Postby dunghnguyen » 17 Aug 2016, 12:15
@Yeti : you should read the instruction from Frank @hondagx35 well at this post to know how to do https://r.tapatalk.com/shareLink?url=ht ... _pid=16145
dunghnguyen
Postby dunghnguyen » 17 Aug 2016, 12:21
What a pity as they don't ship Pi Zero to my country :(
dunghnguyen
