Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby rlsten » 18 Aug 2016, 15:02
rlsten
Postby dunghnguyen » 18 Aug 2016, 18:02
Hi Rod, you cud extend the microsd card as this instruction http://www.runeaudio.com/documentation/ ... tition-sd/
dunghnguyen
Postby delboy711 » 20 Aug 2016, 15:56
Hi @dunghnguyen Yes wifi worked fine once I had the wifi configuration correct. The pHAT DAC from pimoroni.com also worked perfectly with Rune Audio. All I had to do was enable the device tree for HifiBerry.
Yes that ENC28J60 Ethernet card is what I used. They are available from a variety of manufacturers. Note that some of them have different pin numbering to others. You should not have to resort to using one of these. You should be able to get wifi working simply by setting up the configuration files correctly. However if you do have one handy it is a very easy way to get connectivity into a pi zero for fault finding.
delboy711
Postby delboy711 » 20 Aug 2016, 16:29
delboy711
Postby dunghnguyen » 21 Aug 2016, 05:33
Thanks for your confirmation and advice @delboy711. I tried with Pimoroni but they don't ship to my country as well :(
dunghnguyen
Postby flega » 31 Aug 2016, 20:27
PROBLEM SOLVED, FINALLY!! :mrgreen: :mrgreen: :mrgreen: :mrgreen:
I have attach USB -> Ethernet dongle to Zero and reboot Rpi. Then no network interfaces was on ifconfig. Pull out WiFi dongle, reboot, and there was ethernet with IP4 address! Put WiFi dongle back to USB hub, reboot and connect to Rune via web interface with Ethernet IP address. Switch to network and search for my SSID.Have found it, put wifi pass and press connect. There was green arrow that indicated that network is connected but there is no IP assigned for WLAN0. No problem, delete this network, create new and now connect to it with static IP configuration. Reboot, pull out Ethernet USB dongle but there is no connection :( After a few try's I have found that TP Link TL-WN723N don't work with Rune ver.0.4 . Have put another WiFi dongle in USB hub and now I'm connected with my WiFi!
This (TL-WN723N) work with Rune 0.3, work with Open and LibreElec and with Raspbian. Why it don't work with ver 0.4? I think there is a problem with this Linux distro, because now I remember that I have try 0.4 version on my Raspi 2 and also WiFi dongle didn't work. It seems that it is working but no traffic goes through it.
Low cost audio for everyday use: Raspberry Pi 2 -> USB sound card ->preamp+Low-pass Filter NE5532 ->2x TDA7492 amp -> 2 fullrange speakers + 1 bass speaker.
flega
Postby flega » 31 Aug 2016, 21:07
flega
Postby hondagx35 » 31 Aug 2016, 21:29
Postby flega » 31 Aug 2016, 21:56
flega
Postby hondagx35 » 31 Aug 2016, 22:28
Users browsing this forum: No registered users and 44 guests
