Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby flega » 31 Aug 2016, 23:02
Debug ist
Config.txt is
Low cost audio for everyday use: Raspberry Pi 2 -> USB sound card ->preamp+Low-pass Filter NE5532 ->2x TDA7492 amp -> 2 fullrange speakers + 1 bass speaker.
flega
Postby hondagx35 » 31 Aug 2016, 23:10
Postby flega » 01 Sep 2016, 11:44
flega
Postby SlF » 03 Sep 2016, 16:57
Hi all!
awesome work! After two days of trying to install arch, pimusicbox and so on I found this forum post!
It's working well and I shrinked the image for usage with SD Cards <8,5GB.
Does anybody know a good side for uploading a 1,7GB file?
SlF
Postby dunghnguyen » 05 Sep 2016, 01:20
dunghnguyen
Postby SlF » 15 Sep 2016, 11:03
SlF
Postby dunghnguyen » 21 Sep 2016, 11:34
@hondagx35: Hi Frank ! Finally I had the RPi0 now. I have no any issue at all to flash the image on a microSD card 16GB. I tried running that it played perfectly. No issue with LAN even the wifi dongle connection.
The issue I had now are:
- Playing WAV perfectly
- DSD / Hi-Res / Flac are very distorted via usb to external DAC
The bebug of my case is attached from here
As well as the config.txt here http://pastebin.com/UGRsYcRX that I added to activate the HiFiBerry DAC that I am going to test the sound decoded via I2S very soon. For this, I will keep you posted for any further.
Thanks for your attention and any advice is highly appreciated.
I would to say my thanks to @hpeter for his contribution.
dunghnguyen
Postby dunghnguyen » 30 Sep 2016, 01:40
dunghnguyen
Postby dunghnguyen » 30 Sep 2016, 01:42
dunghnguyen
Postby sportsnapper » 28 Nov 2016, 19:47
sportsnapper
