Raspberry Pi Zero Support in 0.4
Re: Raspberry Pi Zero Support in 0.4
Postby tej » 01 Jan 2017, 00:28
I recently purchased a Pi Zero 1.3 plus a Just Boom -Amp zero.
My aim is to use them in a wireless speaker system
I have used Rune audio in the past and the Amp Zero came with a Rune flyer in the box.
I have checked your downloads and cannot find a download for the Pi Zero ?
Is this version 0.4 the answer ?
Can I use an alternative Pi model download ?
I am a Pi beginner, apologies :!:
tej
Postby rlsten » 04 Feb 2017, 01:17
rlsten
Postby janui » 20 Feb 2017, 14:23
Postby rlsten » 09 Mar 2017, 01:52
I just got a new Raspberry Pi Zero W, but when I tried the hpeter image, it wouldn't boot at all. No green light, nothing on the HDMI display. The Pi Zero W works with the standard Raspbian images, and the hpeter image works fine for me with the plain Pi Zero.
Does anyone have any idea what could be wrong?
Thanks,
Rod
rlsten
Postby hondagx35 » 09 Mar 2017, 12:06
Hi Rod,
the kernel and firmware has to be updated for the new Zero W.
Postby rawdevice » 09 Mar 2017, 12:16
rawdevice
Postby rlsten » 09 Mar 2017, 13:50
Thanks Frank and RawDevice! I will try the update and see what happens :shock:
rlsten
Postby McAllister » 09 Mar 2017, 21:51
McAllister
Postby rlsten » 10 Mar 2017, 02:01
I tried RawDevice's instructions on the Pi Zero W with mixed results. I wasn't sure about a couple of things, but this is what I did:
1. Starting with Hpeter's image for the pizero, I deleted everything in the boot partition and copied the new stuff from the boot folder of the firmware download. The link gave me a 404 error, but I was able to find the drivers at .
When I tried to boot, it said that "no filesystem could mount root" and froze.
2. So, I made a fresh hpeter image, and this time copied the new stuff to the boot partition, overwriting the old stuff. This time, it booted to the rune login. However, ifconfig showed no wlan0 entry. Systemctl --type=service showed no wireless service; when I tried to enable it with systemctl restart netctl-auto@wlan0.service, it said something about a dependency was missing and to check journalctl -xn. When I tried to do that, it said there were no journal entries. I also had an entry from systemctl --type=service that "systemd-modules-load.service" had failed.
3. However, when I inserted a WiFi dongle to my USB Hub, that worked perfectly. But there still was no indication in ifconfig or otherwise that the internal WiFi module was recognized. I also had the entry from systemctl --type=service that "systemd-modules-load.service" had failed, but the wlan0.service was active and running.
Does anyone know what I am doing wrong? RawDevice, did you start with hpeter's image, or something else?
Thanks,
Rod
rlsten
Postby rawdevice » 10 Mar 2017, 09:14
rawdevice
Users browsing this forum: Bing [Bot] and 5 guests
