RaspberryPi Newbie DIY AudioServer Advice
Postby clickdex95 » 29 Sep 2020, 14:56
Hi Folks-
I’m a Newbie to RaspberryPi, but having read a bunch of online faqs, I think I’m ready to try to build a RaspberryPi music server.
RaspberryPi music server requirements:
1. Inputs: ALAC library on USB flash drive or external USD SSD Drive
2. Outputs: SPDIF on Coax or Toslinq
3. Control: Ipad
draft architecture :
1. Main board: RaspberryPi 3-B+
2. AudioOutput: HiFi Berry Digi+ Pro
3. Software: RuneAudio
Questions for those who have done a RaspberryPi audio server before:
1. Is the RuneAudioPlayer compatible with the RaspberryPi 3-B+?
2. If not, is there another headless RaspberryPi audioplayer I should use?
3. Is there a better RaspberryPi version to use for this than the 3-B+?
4. Do I need an OS to run Runeaudio on top of?
5. Is there any advantage to buying a 400GB Sdxc card and storing my music library on the same card as the OS?
6. What else can go wrong with my plan?
7. Is there a better way to build a low cost (<$100) RaspberryPi music server that meets my requirements.
Thanks all for your help and advice!
clickdex95
Re: RaspberryPi Newbie DIY AudioServer Advice
Postby ceejayemm » 29 Sep 2020, 17:37
Hi Clickdex95
Yes. I would go for the RuneAudio+Re5 version from the Raspberry PI sub-forum, works very well for me.
Yes - Volumio, Moode etc, but why would you.
You could go to a PI4 but the 3 will be perfectly adequate
No, just flash RA to a microSD and boot from it, configure it, update your Library and you're ready to go.
No, don't do it. Keep the SD card small - 4/8GB is more than enough. Put your music on a separate USB flash drive or a NAS shared drive. Then if (when ?) you need to upgrade your RA installation you won't lose your source and library
Don't know, but the above is pretty foolproof. I haven't used ALAC files, SPDIF on Coax or Toslinq but if the HiFiBerry can provide these then you should be good to go.
Not that I know of.
Chris
ceejayemm
