Raspi3 HifiBerry DAC+ - left right channel swaping/switching
Re: Raspi3 HifiBerry DAC+ - left right channel swaping/switc
Postby robertzombie » 08 May 2016, 16:10
robertzombie
Postby hondagx35 » 08 May 2016, 16:15
Postby Paul » 09 May 2016, 21:37
Hello Frank
It looks like a fix has been developed for this problem - is it possible to provide a little more information on how to implement the changes needed. I know where the configuration file is but I do not have a clue on how to implement the other steps set out in your instructions in this forum post.
Would it be possible for you to provide some simpler steps to follow.
Paul
Paul
Postby rastus » 09 May 2016, 23:11
rastus
Postby Paul » 10 May 2016, 20:09
Hello Rastus / Frank
Thanks for the steer - used the SSH etc and it looks like have have sorted the problem of channel swapping.
Unfortunately it looks like I have done something to Spotify which was running OK (with the channel swap) before I made the changes. Now Spotify will not run - when trying to access Spotify I get the "continuous circle" symbol. There is a similar problem set out on the forum - using Putty to find the "fault log" it says that Runeaudio is failing to connect to Spotify. Spotify is running OK on all other devices.
Would be grateful for any suggestions.
Paul
Paul
Postby hondagx35 » 10 May 2016, 21:43
Postby Paul » 11 May 2016, 17:31
Hello Frank
The error log is:
[img][login as: root
root@192.168.0.11's password:
=============== RuneOS distribution ===============
____ _ _ _
| _ \ _ _ _ __ ___ / \ _ _ __| (_) ___
| |_) | | | | '_ \ / _ \ / _ \| | | |/ _` | |/ _ \
| _ <| |_| | | | | __// ___ \ |_| | (_| | | (_) |
|_| \_\\__,_|_| |_|\___/_/ \_\__,_|\__,_|_|\___/
================ www.runeaudio.com ================
RuneOs: 0.3-beta
RuneUI: 1.3-beta
Hw-env: RaspberryPi 2
Last login: Wed May 11 17:37:36 2016 from 192.168.0.5
[root@runeaudio ~]# uname -a
Linux runeaudio 4.4.9-1-ARCH #1 SMP Fri May 6 12:52:32 MDT 2016 armv7l GNU/Linux
[root@runeaudio ~]#
/img]
Is this what you wanted to see?
Thanks for you help.
Paul
Paul
Postby sarucyel » 21 May 2016, 13:40
The channel swapping problem is gone, this is great news and than you veryvmuch for the installation instructions
Sarucyel
sarucyel
Postby Paul » 02 Jun 2016, 18:09
Hello Frank
I still have the issue with not being able to play Spotify.
Rune recognises my playlists. When a playlist is selected the queue is populated but when a track is played nothing happens.
Is there a way to locate the configuration file for spoitify - another forum post uses the comman line - /etc/spop/spopd.conf - when I use this I get the following:
[root@runeaudio ~]# /etc/spop/spopd.conf: line 6: [spop]: command not found
-bash: /etc/spop/spopd.conf:: No such file or directory
[root@runeaudio ~]# /etc/spop/spopd.conf: line 7: spotify_username: command not found
[root@runeaudio ~]# /etc/spop/spopd.conf: line 8: spotify_password: command not found
[root@runeaudio ~]# /etc/spop/spopd.conf: line 11: audio_output: command not found
[root@runeaudio ~]# /etc/spop/spopd.conf: line 12: high_bitrate: command not found
[root@runeaudio ~]# /etc/spop/spopd.conf: line 13: offline_high_bitrate: command not found
[root@runeaudio ~]# /etc/spop/spopd.conf: line 17: cache_path: command not found
Any idea what might be happening?
Paul
Paul
Postby hondagx35 » 02 Jun 2016, 20:20
