I'm already supplying the amp with only 20V (range is 15-32), and the input gain on it is set to the weakest it can be, so I don't think I can change anything there. The DAC isn't the + version, so there is no hardware volume control option and I'm using Rune's software volume control. The speakers are built-in to the walls, and my guess is that they are just really sensitive.
Before I added the DACs, I was using the pi's default output (the hiss at low-ish volume levels was awful, and the intention was always to add DACs), and the overall volume level was lower than it is with the DACs (normal listening was ~40-60, and uncomfortable began around 80-90).
What would be the best way to lower the output volume? I have 4 of these setups running various zones in the house, so cheap would be good
I'm wondering though if a passive (resistor) attenuator might raise the average SNR because it would allow the DAC to run at a higher level for a given volume level?
Anybody have any ideas/thought?
