Reinstalling shairport
Postby dror » 19 Dec 2017, 09:26
I have two Rpis each running Rune.
I think somehow my shairport is broken on one of them, as no Airplay source connects successfully. I tested the sources with the other Rpi and the connection is successful.
I want to avoid starting the faulty machine with a new image. Can I just repair (reinstall) Shairport?
Thanks,
Dror
dror
Re: Reinstalling shairport
Postby janui » 21 Dec 2017, 17:21
Hi dror,
shairport is no longer supported, so there is no standard installation available in the Arch Linux repositories. However there is a build package on the Runeaudio github site, here: https://github.com/RuneAudio/RuneOS/tre ... rport-rune. But I do not see an arch6h tar.xy version for the Pi 1 (model A, B, B+, etc.). So, a reinstall would only be possible for an arch7h Pi 2/3 B. It's the same story for the shairport-sync (replacement for shairport), this will only work on the Pi 2/3 B, see here: replace-shairport-with-shairport-sync-ios-9-compatibility-t2872.html#p9817
Postby dror » 21 Dec 2017, 19:49
Hi janui,
Thanks for the reply. I have a rpi2.
Is there a "one line" (or more..) command for installation from the rune git?
dror
Postby janui » 21 Dec 2017, 20:18
Postby dror » 27 Dec 2017, 18:44
dror
Postby hondagx35 » 27 Dec 2017, 21:39
Hi dror,
value 127 is returned by /bin/sh when the given command is not found within your PATH system variable and it is not a built-in shell command. In other words, the system doesn't understand your command, because it doesn't know where to find the binary you're trying to call or the file is not executable.
Postby janui » 28 Dec 2017, 01:06
Postby dror » 28 Dec 2017, 09:37
dror
Postby janui » 28 Dec 2017, 11:33
Postby dror » 28 Dec 2017, 17:30
https://pastebin.com/cHcUsPd5
This is my debug info.
If you meant something else please tell me.
Thanks for your help
dror
