RemotePi Board Plus 2015 & RuneAudio
Postby guyb » 08 Oct 2015, 20:55
Hey all,
I was thinking of getting one of these to provide on/off via a power button and via a remote along with the addition of play/pause/next/previous via remote if I can get it working:
http://www.msldigital.com/collections/a ... -plus-2015
On their support pages they have scripts for setting it up for Volumio (scroll down). Will this work with RuneAudio:
http://www.msldigital.com/pages/support ... -plus-2015
Guy
guyb
Re: RemotePi Board Plus 2015 & RuneAudio
Postby hondagx35 » 09 Oct 2015, 12:14
Postby guyb » 11 Oct 2015, 08:49
Great, thanks. It should arrive next week so I'll try and get it working and report back.
Guy
guyb
Postby guyb » 16 Oct 2015, 23:06
OK, so I have the RemotePi now.
I have written the script and service and everything works perfectly :)
I am now trying to get LIRC to work!!!
I am try to use a silver apple remote with the RemotePi.
I have tried to follow a few guides but can't get it to work.
I can't get irrecord to work so have been trying to find a conf for the remote online but not sure if it is the right one.
Also, I am not sure if I am supposed to map the GPIO pins used for the IR sensor with LIRC but I don't know which ones are used.
Essentially I am stabbing in the dark!!!
Can anyone help?
Guy
guyb
Postby XploD » 17 Oct 2015, 10:30
Irrecord doesn't work on Archlinux. If you have a spare (micro)SD card somewhere, you can put Raspbian on it and create config file from there, or find it somewhere online. For the GPIO pin, try to look here: http://www.msldigital.com/pages/support ... plus-2015/ , search for "The Hardware" and there's a table with GPIO pins used. You can also track connections on the board where IR sensor is connected to be sure.
About LIRC, if you use Raspberry Pi 1, take a look here: http://yjo-blog.blogspot.jp/2015/05/run ... tting.html . If you use Pi2, I have a tutorial which I use and which works, somewhere in Word file. In case of any further problems with LIRC, let me know and I will write it here.
EDIT: Here you go: http://buzzthisnow.com/ir-remote-with-l ... archlinux/
Music taste:
Hi-Fi:
Mixer: Nady Audio MM-242
XploD
Postby guyb » 19 Oct 2015, 17:34
guyb
Postby guyb » 19 Oct 2015, 17:43
Hey all,
Since I managed to the RemotePi working with the hardware/remote power switch and then using LIRC I thought I would post the instructions in case someone else is looking for a solution.
I have also sent the instructions for the hardware/remote power up and down to Matt at MSL and he is going to post the instructions on the support pages for the RemotePi.
First, run the run the following 2 commands:
syslemctl stop netctl-auto@wlan0
systemctl disable netctl-auto@wlan0
As mentioned else where on the forums, your RuneAudio box will go from taking about 2 minutes to boot to about 20 seconds!
Next, the instructions for adding the scripts for powering up and down and amending the RuneUI so the shutdown button uses the RemotePi too!
Create the RemotePi Script & Service
Key in
cd /etc
sudo nano irswitch.sh
Copy and paste the following text into the editor window
#!/bin/bash
# this is the GPIO pin receiving the shut-down signal
GPIOpin1=14
echo "$GPIOpin1" > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio$GPIOpin1/direction
while true; do
sleep 1
power=$(cat /sys/class/gpio/gpio$GPIOpin1/value)
if [ $power != 0 ]; then
echo "out" > /sys/class/gpio/gpio$GPIOpin1/direction
echo "1" > /sys/class/gpio/gpio$GPIOpin1/value
sleep 3
sudo poweroff
fi
done
Press ctrl+x to exit, y to confirm, enter to save the file
Key in
sudo chmod +x irswitch.sh
Create the startup service
Key in
cd /usr/lib/systemd/system
sudo nano irswitch.service
[Unit]
Description=RemotePi Service
After=systemd-modules-load.service
[Service]
Type=simple
ExecStart=/usr/bin/bash /etc/irswitch.sh
[Install]
WantedBy=multi-user.target
Key in
systemctl enable irswitch
That's if for the power up and down script for the hardware button on the RemotePi and startup/shutdown via remote.
You should now pair your remote as described here: https://youtu.be/fOLIoRlQ1RE
To invoke a shutdown from the RuneAudio UI
Key in
cd /etc
sudo nano shutdown.sh
#! /bin/bash
GPIOpin=15
echo "$GPIOpin" > /sys/class/gpio/export
# execute shutdown sequence on pin
echo "out" > /sys/class/gpio/gpio$GPIOpin/direction
echo "1" > /sys/class/gpio/gpio$GPIOpin/value
sleep 0.125
echo "0" > /sys/class/gpio/gpio$GPIOpin/value
sleep 0.2
sleep 0.4
Key in
chmod +x /etc/shutdown.sh
Edit the RuneAudio file so that the 'Turn Off - Shutdown’ option from the menu powers down using the RemotePi
Key in
nano +609 /var/www/command/rune_SY_wrk
Edit line 609 -
Change:
sysCmdAsync(‘poweroff');
To:
sysCmdAsync('/etc/shutdown.sh');
Right, that the RemotePi all setup!
Next, and this is optional and a bit of a pain, but if you want to use LIRC for other remote control functions then there is more work to do.
This is the best guide to use which I found posted elsewhere on the forum: http://yjo-blog.blogspot.jp/2015/05/...tting.html?m=1
Following the instructions as is and you should be able to get it working however...
One thing that is different to the guide for the RemotePi is that step 8 should be
8. Creating /etc/modprobe.d/lirc.conf
options lirc_rpi gpio_in_pin=18
Also, as mentioned in the post, irrecord does not work in RuneAudio. I tried downloading a few .conf files from the internet for the Apple remote that I am using but no joy.
So I did exactly what is suggested in the post. Installed Volumio and used irrecord to generate the .conf file for the remote you are using. Once the conf is generated by irrecord you can view it and copy the data to use in RuneAudio.
Here is a few sites that helped be setting up LIRC on Volumio so I could get the .conf file for my remote.
https://volumio.org/forum/how-instal...umio-t360.html
https://volumio.org/forum/using-remo...mio-t1923.html
Here is some details on the remote commands that you can add to the '/etc/conf.d/lircrc' file for sending commands to MPD using MCP:
https://wiki.archlinux.org/index.php..._MPD_with_lirc
Guy
guyb
Users browsing this forum: Bing [Bot] and 3 guests
