replay gain - auto setting cannot be selected
Postby sarucyel » 25 Apr 2016, 02:17
I noticed the selection of "auto" does not appear to stick, i fell back on "album" instead but thought i'd mention it.
Sarucyel
sarucyel
Re: replay gain - auto setting cannot be selected
Postby hondagx35 » 25 Apr 2016, 08:49
Hi Sarucyel,
thank you for reporting this.
The setting should work as expected, only the mpd config page doesn't show the correct value.
You can check this by browsing the debug info page (mpd.conf section).
I fixed this in the dev branch.
If you are on a newer device (RP2/RP3 or ODROID) you can update via "git pull".
