Restoring playlist containing cue sheet
Postby Beelzebassie » 11 Nov 2014, 11:57
When restoring a saved playlist containing a cue sheet of an unsplit audio file, the queue will show that unsplit file times the number of separate tracks defined by the cue sheet.
E.g.:
Beelzebassie
Re: Restoring playlist containing cue sheet
Postby ACX » 11 Nov 2014, 13:10
Interesting. Can you please spare me a bit of time checking and tellimg me the behaviour of other MPD clients (e.g. MPDroid or GMPC) in the same situation?
Postby Beelzebassie » 11 Nov 2014, 13:39
GMPC shows the same behavior (I've also tried creating a playlist through GMPC):
EDIT:
Auremo returns the same result.
Beelzebassie
Postby Beelzebassie » 23 Nov 2014, 12:53
Encountered another (minor) bug:
Cue sheets referring to one-track files do not load when the file name contains unicode(?) characters (i.e.: ü, ö, etc.).
EDIT: Found the culprit: It was not RA or MPD, but a bug in CUEtools which saves CUE sheets in ANSI instead of UTF.
Beelzebassie
Postby ACX » 23 Nov 2014, 15:58
