Room correction?
Room correction?
Postby jonas18z » 21 Oct 2014, 17:57
Is it possible to add some Room correction like miniDSP or is the Raspberry pi to slow?
jonas18z
Re: Room correction?
Postby dwijtsma » 26 Nov 2014, 09:53
Sorry for responding on an old post, but room correction would really be a nice feature. My brother uses room correction and this really improves the sound.
Would it be possible to measure the impulse response of a room with the pi using a microphone? Or measure the impulse response with a PC and import the data into the pi? Importing should be possible I guess but I don't know how much computing power is needed to add FIR filtering to the raspberry pi.
dwijtsma
Postby skrodahl » 26 Nov 2014, 20:33
HifiBerry supports both FIR and IIR:
http://www.crazy-audio.com/2013/10/chan ... -mini-dac/
There's been talks about bruteFIR, don't know how far it's gotten. Seems to be pretty CPU intensive though:
http://www.crazy-audio.com/2014/01/fir- ... pberry-pi/
-skrodahl
skrodahl
Moderator
Postby koslowj » 28 Dec 2014, 23:42
On the German board "Aktives Hoeren" a contributer named "frankl" describes software experiments with Linux (Arch Linux) concerning high quality audio, using somewhat more powerful hardware than a Raspberry Pi:
http://www.aktives-hoeren.de/viewtopic.php?f=30&t=4532
On his home-page, in English, he even offers his programs for downloading, including a version for the Raspberry Pi
http://frank_l.bitbucket.org/stereoutils/index.html
http://frank_l.bitbucket.org/stereoutils/player.html
Hope this is useful for somebody here!
koslowj
Postby Tinitus » 27 Oct 2015, 20:56
digging up this feature request. integration of bruteFIR would reall be nice. Daphile has it integrated now. My dream would be RuneAudio to sox up/downsample all files to 24/96 ( inorder to be able to use USB 1.0 spec), room correction through bruteFIR and then go through a USB 1.0 Adum chip (http://hackaday.com/2014/04/27/galvanic ... -computer/ for instance) for galvanic isolation into the DAC. My bet is that would beat or be equal to euipment at least 50x more expensive. The advantage of using only 24/96 would be that only one filter for the room correction would be needed.
For those who read German:
http://www.aktives-hoeren.de/viewtopic. ... 4&start=60
Greetings
Uwe
Computing power of my C1 should be enough to implement bruteFIR (the same should be true for Pi) if not daisy chain 'em
Tinitus
Postby maxonline » 13 Dec 2015, 12:02
Hey, If you like, you can already get it ... RuneAudio & RPI 2 are able to do it as you like :-)
My setup in short :
mpd with pipe-out and brutefir package from the-new-4-core-raspberry-pi-t862-150.html#p5733
in mpd.conf :
resampling up/down to 96/24 ( samplerate "sox very high" )
audio output ( type "pipe" ) to bruteFIR
in brutefir conf file :
needed coeff&filter
output via device "alsa" { device: "hw:sndrpihifiberry"; ignore_xrun: true; } ( miniTOSLINK optical out in this case )
USB link to a CA DACMagic will do the job as well, but you have to (down)sample to 44/16 due to the DACMagic USB limit.
Ciao
max
maxonline
Postby Tinitus » 15 Jan 2016, 21:19
Hi Max,
thanks for your answer. I only saw it a fourtnight ago. I have a Odroid C1 and somewhere I have the version with pipeout to brutefir on my PC. I have several questions, Where can I alter mpd.conf over the WebGUI or do I need to SSH into the Odroid C1? How does the commandline "pipe to brutefir" look like? I would have to find out what the hardwarename four the sound of the C1 for the alsa out of brutefir is. Is the setting for using usb instead of TOSLink the same? My DAC handles everything up to 32/192 over usb. If I find time I will have to tinker around with my spare C1. Given the fact that I do not yet have a correction file I would start with a 0 filter in brutefir.
Thanks again for the reply
Best Regards
Uwe
Tinitus
Postby maxonline » 16 Jan 2016, 14:56
maxonline
Postby °pdi° » 16 Jan 2016, 17:35
i need a brutefir-package for armv6 (Raspberry Pi B+). I tried to install base-devel on the raspberry and get this error-message: " libtool and libltdl are in conflict"
Btw., i'm not familiar with crosscompiling and the arch-build-system. Maybe it 's better this way: Please, can someone build brutefir for armv6?
Klaus
°pdi°
Postby °pdi° » 17 Jan 2016, 13:20
°pdi°
