rotate screen
rotate screen
Postby danco89 » 09 Mar 2017, 04:40
need to know how to rotate screen
is there a step by step on this found some code
# LCD settings
# 180 degrees
lcd_rotate=2
# Normal
#lcd_rotate=0
how do you enter
danco89
Re: rotate screen
Postby sysco » 09 Mar 2017, 08:21
sudo nano /boot/config.txt
display_rotate=0 Normal
display_rotate=1 90 degrees
display_rotate=2 180 degrees
NOTE: You can rotate both the image and touch interface 180º by entering lcd_rotate=2 instead
display_rotate=3 270 degrees
display_rotate=0x10000 horizontal flip
display_rotate=0x20000 vertical flip
sysco
Re: rotate screen
Postby danco89 » 09 Mar 2017, 14:45
where and how do you enter this
danco89
Re: rotate screen
Postby sysco » 09 Mar 2017, 15:43
sysco
Re: rotate screen
Postby danco89 » 09 Mar 2017, 19:17
thank you for trying sounds like i need to some research and read the docs
danco89
Re: rotate screen
Postby andib » 17 Mar 2017, 21:40
andib
Re: rotate screen
Postby danco89 » 17 Mar 2017, 22:36
cant figure out how this is done
not a coder is there a step by step
or can you update in next version of
rune
danco89
Re: rotate screen
Postby hondagx35 » 18 Mar 2017, 17:29
Hi danco89,
connect your SD card to your computer and navigate (file browser) to:
/boot/config.txt
Open this file with your text editor and search for the line:
lcd_rotate=2
Change that number to your needs.
lcd_rotate=0 Normal
lcd_rotate=1 90 degrees
lcd_rotate=2 180 degrees
lcd_rotate=3 270 degrees
Save the file and put the SD card back in your Pi.
Re: rotate screen
Postby danco89 » 21 Mar 2017, 02:10
thank you for being patient
figured it out i didn't know i
needed to use note pad
danco89
