Rotel RDD-1580 on the way
Re: R: Rotel RDD-1580 on the way
Postby ACX » 15 Aug 2014, 01:03
So you managed to get a smooth playback at least up to 24/96? That's a pretty good result, considering the limits of the Rpi's USB/Ethernet shared bus. Try also to tweak the buffer settings looking for eventual further improvements.
Re: Rotel RDD-1580 on the way
Postby cmh714 » 15 Aug 2014, 02:19
Yes very clean to that point and even at 176 and 192 its mostly not noticeable just on occasion.
Have my audio buffer at 16MB and buffer before play at 30%, not sure its any change, but will keep on trying anything I can find or get from you Guys.
Will also trying the setting dwc_otg.fiq_fsm_mask=0x7 instead of the original 0x3 to see if anything changes for the better
Postby cmh714 » 16 Aug 2014, 22:27
Postby cmh714 » 18 Aug 2014, 16:32
So continuing on this thread...I couldnt find any newer driver that was compiled and too many people already tried and couldnt compile it, so that seems out for now.
I am getting the transmit error on a clean 0.3 install, with both a B and a B+ Pi, and trying to plug it directly into the Pi and/or trying to have it in the powered USB Hub.
My wifi is a Canakit wifi dongle, my router an Asus WL-500G Premium running PacketProtector (OpenWRT based).
Return to Compatibility list
